1999 Chevy Blazer
125,000 MILES • 6 CYL • AWD • AUTOMATIC
ANDREACALDWELL
My car hAS BEEN WORKING FINE AND NOW IT WILL NOT START, BATTERY IS GOOD, CHECKED FUSES, AND RELAY. wHAT COULD IT BE? I HEARD IT MAY BE MY FUEL PUMP. iF SO, HOW DO I INSTALL IT? wHERE IS IT LOCATED?
tHANK YOU,
Aug 24, 2009 at 6:34 AM
JDL
  • 16,098 POSTS
Hello, have you done any basic testing? If the vehicle cranks good but won't start, have a helper crank it, while you check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. The pump should be in the gas tank.
Aug 24, 2009 at 6:41 AM
