1999 Chevy Blazer
MIKE1979
Electrical problem
1999 Chevy Blazer 6 cyl Four Wheel Drive Automatic
The injector have stoped firing it will run as long as you pour gas in the throttle body the fuel rail has 60psi
Apr 29, 2009 at 1:28 PM
  • 75,988 POSTS
Check ECM fuse 1 15amp if okay-check for power at the pink wire on the injector connector.
Apr 29, 2009 at 1:39 PM
