1999 Chevy Blazer
114,000 MILES • 6 CYL • 4WD • AUTOMATIC
PATBB
ENGINE OFTEN WILL NOT START UNLESS I BLEED THE PRESSURE OFF OF THE FUEL SYSTEM AT THE PRESSURE RELIEF VALVE ON THE INJECTION FEEDER LINE. THE FUEL PUMP WAS REPLACED BUT NO CHANGE. BLEEDING OFF THE PRESSURE WORKS EVERY TIME.
Aug 20, 2008 at 7:48 AM
JETSA
  • 117 POSTS
This is an odd one but I would venture to guess the issue lies with the fuel pressure regulator if the pump was installed correctly and it is the right pump.
Aug 22, 2008 at 2:24 PM
