1999 Chevy Blazer
141,756 MILES • 6 CYL • 4WD • AUTOMATIC
REESER
My blazer stopped running on me going down the road. The check engine light did not come on. It did not sputter or stall it just stopped. Now it will not start. I pulled the coil wire and the coil has a spark. What could be wrong? My security light is blinking also. Could this have something to do with pass lock?
May 23, 2008 at 9:42 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:609e2cd054="Reeser"]1999 Chevy Blazer 6 cyl Four Wheel Drive Automatic 141756 miles
My blazer stopped running on me going down the road. The check engine light did not come on. It did not sputter or stall it just stopped. Now it will not start. I pulled the coil wire and the coil has a spark. What could be wrong? My security light is blinking also. Could this have something to do with pass lock?[/quote:609e2cd054]
Have you check to make sure it is getting fuel?
It could be the Fuel Pump, Fuel Pump Relay, Fuel Pressure Regulator.
You say you have you have spark from the coil. Did you check to see if you have spark at the Plugs? And what color is the spark? It should be Bluish/White. If it is Orange the spark is weak.
Post responses here
May 24, 2008 at 12:58 PM
