1998 Chevy Blazer won't crank
TSHIPLEY
  • 1998 CHEVROLET BLAZER
Other Category problem
1998 Chevy Blazer Engine Size unknown Four Wheel Drive Automatic 48,000 miles
When I turn my key to start the blazer I hear the buzzing noise and that's it. The mechanic got it started somehow. I drove the Blazer for 2 days was unloading it after shopping while listening to the radio got back in the car and it wouldn't start again. Now my mechanic is stuck I need my car back do you have any ideas? The battery is brand new. He pulled the starter out and had it checked, he then checked all of the relay things and has determined that he doesn't know but he is checking into it. Any thoughts
Tuesday, February 12th, 2008 AT 9:40 AM
2CARPRO JACK
  • 11,533 POSTS
Need to test the small wire at the starter for 12 volts when key is in crank position. We will go from there
Saturday, January 30th, 2021 AT 9:32 AM
RT3JROC
  • 5 POSTS
Hey my car is just buzzin when I try to start it and I was wondering how did your mechanic start it if u have any idea thanks
2CARPRO JACK
  • 11,533 POSTS
Make sure the battery is good and all connections are clean and tight
