Your security system is called PASSLOCK. Being that the light is on, and not blinking, usually means that the passlock main box (the brain) has failed or has a problem. This should be diagnosed at a dealer, because they have the proper computer diagnostic scan tools.
If the mechanic changed the ignition switch with the security light on, and not flashing, then he or she probably does not have the proper diagnistic tool for your problem. They just shot in the dark hoping to fix the problem. This will cost you a lot of money - so take it to the dealer.
Tuesday, December 2nd, 2008 AT 2:33 PM
