1998 Chevy Blazer will not start
171,864 MILES • 6 CYL • 4WD • AUTOMATIC
TATROE
it will trun over but it will not run at all I went and got a new battery and it will not start at all till and it is getting fuel to the engine I need to know want it could be
Dec 28, 2007 at 10:54 AM
MERLIN2021
  • 17,250 POSTS
Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
Dec 28, 2007 at 11:00 AM
