1998 Chevy Blazer water leak
1998 CHEVROLET BLAZER
129,000 MILES • 6 CYL • 4WD • AUTOMATIC
MARIANNA61
I just replaced the radiator with a brand new one, now the car leaks. Only after it's been driven, sometime a little, sometimes alot. It doesn't overheat at all. What could this be?
Aug 27, 2010 at 2:43 AM
LEGITIMATE007
  • 5,121 POSTS
do you have an approximate location where its leaking at?
Aug 27, 2010 at 2:47 AM
MARIANNA61
it's towards the front in the middle behind the radiator. About at in the middle of the front tires.
Aug 27, 2010 at 3:21 AM
LEGITIMATE007
  • 5,121 POSTS
sounds like you have a leak in the radiator itself, or at the lower radiator hose.
Aug 27, 2010 at 5:32 AM
MARIANNA61
radiator is brand new right out of the box. We did not replace the thermostat. We will replace that and check the hoses. Thank you
Aug 27, 2010 at 7:15 AM
