1998 Chevy Blazer Transfer Case Control Module
11,200 MILES • 6 CYL • 4WD • AUTOMATIC
BDIII
at low speed (20 mph) there is a humming sound in the front end, when you shift it into 4WD the sound goes away, go back to 2WD the sound returns, could this be the transfer case control module, and if so how do we go about fixing it?
Feb 14, 2009 at 2:51 AM
SWILLIAMS
  • 597 POSTS
The noise is probably from lack of use. The transfer case motor has nothing to do with it. Basically what you are hearing is probably a bearing or gear that has some rust/damage from lack of lubrication if you don't use the 4X4 much.
Feb 19, 2009 at 1:43 AM
