1998 Chevy Blazer Tranny slips in reverse, fluid is dark re
1998 CHEVROLET BLAZER
194,000 MILES • 6 CYL • 4WD • AUTOMATIC
SUPERSKINSFAN
I would like your advise on how to fix my transmission. It slips in reverse, seems to shift ok though. The fluid is darker than usual but does not smell burnt. The 4 wheel drive works fine and it shifts through all the gears normally, just wants to slip in reverse. I was wondering if I should change the fluid and filter or put some kind of additive in it or if you think this is something more serious?
Jan 21, 2008 at 3:37 AM
DENNYP
  • 1,824 POSTS
Sounds like it is due for an overhaul. You might also have a partially stripped reaction shell inside the transmission.
Jan 21, 2008 at 1:57 PM
