1998 Chevy Blazer Tranny fluid
150,000 MILES • V8 • 4WD • AUTOMATIC
BALLRED62
When I check my tranny fluid when the engine is cold, it registers way over the "hot" line. When I check it with the engine hot, it barely registers on the dip stick. Any idea why?
Aug 12, 2008 at 4:41 AM
JETSA
  • 117 POSTS
Hmm. When checking the fluid level, you should always run the gears from lowest low to park before checking, with the engine running. If you are either checking the fluid level without the engine running, or checking it right after startup in the morning without having running it through the gears, you may get erroneous readings. Other than that, that one is a stumper to me.
Aug 12, 2008 at 11:40 PM
