1998 Chevy Blazer tps/pedal position sensor
1998 CHEVROLET BLAZER
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
ARKWOLF
On my 98 blazer s10, I have changed my tps by the throttle body twice, but the code keeps popping up tps/pedal position sensor a. Is it storing them or is there a second pedal position sensor?
Jun 29, 2008 at 1:34 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:47f91bebdd="arkwolf"]Computer problem
1998 Chevy Blazer 6 cyl Four Wheel Drive Automatic 125000 miles
On my 98 blazer s10, I have changed my tps by the throttle body twice, but the code keeps popping up tps/pedal position sensor a. Is it storing them or is there a second pedal position sensor?[/quote:47f91bebdd]
What is the DTC you are getting....
P0120 Throttle/Pedal Position Sensor/Switch A Circuit Malfunction
P0120 ETS Main Throttle Position Sensor Malfunction
P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch A Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch A Circuit Intermittent
After replacing the TPS did you have the code cleared. If so how was it cleared? If not you will need to have it cleared.
Jun 29, 2008 at 3:10 AM
