1998 Chevy Blazer tools
FISHERMANMINNESOTAVIKINGS
Brakes problem
1998 Chevy Blazer 6 cyl Four Wheel Drive Automatic
I read about the brake repiar for front brakes on a chevy blazer i was just wondering see i need to know what tools to use i saw that i need a c-clamp and a wrench. If you could please tell me if the wrench is metric or what or maybe the size od it so i can buy it at the store also what size c-clamp do i need thankyou
Jun 9, 2009 at 8:38 AM
BILLYMAC
  • 2,204 POSTS
Hi the c clamp a 8 inch will work.
the wrench buy a cheap socket set 3/ 8 drive and you will have the right one .there is such a variation
of bolts that it is hard to say. usually 15 mm or a 10 mm or allen 10 mm.wish i could be more precise but can,t good luck billymac
Jun 10, 2009 at 12:55 PM
