1998 Chevy Blazer The radiator
184,000 MILES • 6 CYL • 4WD • AUTOMATIC
DEZZY2107
How do I install a radiator in a Chevy Blazer?
Nov 15, 2008 at 4:13 AM
  • 110,248 POSTS
HI:
First you will need to drain the coolant. After that, remove both the upper and lower radiator hose. Also, if the blazer has an auto trans, there will be two trans cooling lines to remove from the rad also. Next, remove the radiator shroud from the radiator and carefully slide it back toward the engine. Now you will need to remove 4 bolts that hold the radiator to the core support. Once they are removed, the radiator is ready to be removed. Make sure nothing else is attached to the radiator like engine cooler. If so, it will most likely be bolted also.
To replace, just reverse the order.
Nov 15, 2008 at 8:23 AM
SWILLIAMS
  • 597 POSTS
Watch out for the oil cooler lines. When you install them in the new radiator use new sealing washers to prevent leaks.
Nov 17, 2008 at 2:23 AM
