My sunroof is stuck in the up position and won't go down. How do i put it down.
Nov 9, 2010 at 10:28 AM
HMAC300
✓Experienced Mechanic
if it hasn't blown fuses and the relay and everything electrical is good you'll probably have to disconnect the cable that operates it from the motor if it'snot broken already. you have to dropthe headliner to get to it and it may not be repairable as it's an assembly when installed.
