1998 Chevy Blazer STARTING PROBLEMS
KENS INFO
Engine Performance problem
1998 Chevy Blazer 6 cyl Four Wheel Drive Automatic
WILL NOT START WHILE KEY IS IN NORMAL START POSITION, YOU HAVE TO JUST BUMP THE STARTER AND RELEASE QUICKLY,USUALY AFTER A FEW TRIES IT WILL PROBABLY START.
THIS ONLY WORKS IN WARM WEATHER IN COLD WEATHER EATHER SOMETIMES WORK,IN REAL COLD , FORGET IT
IT HAS ABOUT 40LBS.FUEL PRESSURE AND IT HAS FIRE AT THE SPARK PLUGS.
I HAVE CHECKD THE CYLS.SEVERAL TIMES AFTER TRYING TO START,AND IT HAS ALWAYS DRY,THAT IS TO SAY ITS NOT FLOODED.
AFTER IT STARTS ONCE YOU CAN SHUT IT OFF AND IT WILL RESTART FOR THE REST OF THE DAY.BUT THE NEXT YOU HAVE TO DO IT ALL OVER AGAIN.BUT THAT ONLY WORKS IN THE SUMMER,IN COLDER MOS. YOU HAVE TO LEAVE IT RUNNING.
Jan 25, 2009 at 10:22 AM
CYBERWOLPH
The fuel pressure at the schrader valve should be around 60 psi +/- if its the CMFI (Central Multiport Fuel Injection) model. If its lower than that the Injector wont work.. Check your fuel filter may be clogged and needs replaceing.. After that I would check the fuel pump.. But there should be at least 60ish PSI there at the schrader.. Read this post... Full of info on testing and checking...
http://www.2carpros.com/forum/here-vp484339.html#484339
Feb 13, 2009 at 12:28 AM
