Engine Performance problem
1998 Chevy Blazer 6 cyl Four Wheel Drive Automatic
WILL NOT START WHILE KEY IS IN NORMAL START POSITION, YOU HAVE TO JUST BUMP THE STARTER AND RELEASE QUICKLY,USUALY AFTER A FEW TRIES IT WILL PROBABLY START.
THIS ONLY WORKS IN WARM WEATHER IN COLD WEATHER EATHER SOMETIMES WORK,IN REAL COLD , FORGET IT
IT HAS ABOUT 40LBS.FUEL PRESSURE AND IT HAS FIRE AT THE SPARK PLUGS.
I HAVE CHECKD THE CYLS.SEVERAL TIMES AFTER TRYING TO START,AND IT HAS ALWAYS DRY,THAT IS TO SAY ITS NOT FLOODED.
AFTER IT STARTS ONCE YOU CAN SHUT IT OFF AND IT WILL RESTART FOR THE REST OF THE DAY.BUT THE NEXT YOU HAVE TO DO IT ALL OVER AGAIN.BUT THAT ONLY WORKS IN THE SUMMER,IN COLDER MOS. YOU HAVE TO LEAVE IT RUNNING.
Jan 25, 2009 at 10:22 AM
