1998 Chevy Blazer Starter problems ?
1998 CHEVROLET BLAZER
16,500 MILES • 6 CYL • 2WD • AUTOMATIC
VILLALALO2002
When you go to start it wants to but does not we push key back then go start again and it will start we have already replaced starter still doing the same thing no difference with new starter
Jul 15, 2010 at 9:31 AM
JDL
  • 16,098 POSTS
Are you saying it cranks good but won't start or it won't even crank? If it cranks good but won't start, check fuel pressure. Sometimes if you cycle the key two or three times before you crank it, it helps the fuel system, pressure up.
Jul 15, 2010 at 10:14 AM
VILLALALO2002
Yes it cranks well but will not start you have to move key back 1-2 times than it will start
Jul 15, 2010 at 11:13 AM
