1998 Chevy Blazer Radiator intake
100,289 MILES • 6 CYL • 4WD • AUTOMATIC
BAKERBARN
I just had a new radiator replaced because it was cracked and now the radiator intake is leaking. Should the repair shop where the radiator was replaced have seen the intake leaking also? Is $400 to $500 an accurate repair estimate?
Nov 12, 2009 at 1:51 AM
  • 110,248 POSTS
Actually, one would think they would have seen it, but if they were busy, they most likely replaced the radiator and moved on.
As far as the cost, yes that sounds accurate. It's a labor intense job.
Nov 13, 2009 at 12:01 AM
