1998 Chevy Blazer Question
KFORD3
1998 Chevy Blazer Four Wheel Drive Automatic
I have a 98 chevy blazer and it will not start unless you spray gum cutter in the throtle body. We have already replaced the throtle body, fuel pump, and distributor. What should we try next?
Apr 26, 2010 at 5:50 AM
  • 75,988 POSTS
Check the fuel pressure if its within specs and also for injector pulses-to include testing the fuel pump relay and the oil pressure sending unit/coolant temperature sensor.
Apr 26, 2010 at 7:21 AM
