1998 Chevy Blazer no fuel
INFINITY15
  • 1998 CHEVROLET BLAZER
  • 6 CYL
  • 11,700 MILES
I am not getting any fuel to carbeurator. I have gas and pressure out of the filter, but nothing to carb. Car will start if I put gas into carb but only run till that is used up. Thanks chuck baker
Friday, July 11th, 2008 AT 11:38 AM
OBXAUTOMEDIC
  • 3,711 POSTS
You will not see gas in what you are calling the carborator what you are looking into is the throttle body. Gas is sprayed directly into the Cylinders VIA fuel injectors. The injector are located under what is called the Plenum which is what the throttle body is bolted to.
You will need to check the fuel pressure at the test connection which is on the drivers side rear of intake.
Friday, July 11th, 2008 AT 11:57 AM
MASTERTECHTIM
  • 4,750 POSTS
Is the theft light on the dash flashing or does it go out after key is turned to run? Is the check engine light lit up on the dash board?
Friday, July 11th, 2008 AT 11:58 AM
INFINITY15
I don't have a theft light and check engine goes out when car starts. This same thing happened 3 months ago, but restarted 2 days later and ran till yesterday.
Friday, July 11th, 2008 AT 12:15 PM
