1998 Chevy Blazer no fluid coming out of bleeder screw in l
1998 CHEVROLET BLAZER
21,000 MILES • 6 CYL • 4WD • MANUAL
TERRYRUXPIN
today I replaced my pads , rotors, and calipers in the front. Then I bleed the front brakes. After i was done, I decided to start over and bleed all 4 brake lines. When I loosened the bleeder screw on the left rear, there was barely any fluid coming out when the pedal was pumped. What would cause this. Is the caliper bad??? The master cylinder was full. The calipers on the rear are over 10 yrs old, I must replace them anyway because I broke off the bleeder screw on the rear right one. HELP!
Nov 12, 2009 at 9:29 AM
  • 110,240 POSTS
Can you describe how you tried to bleed them or the process used?
Nov 12, 2009 at 11:36 PM
