How do you bleed the master clynder. I have a caliper sticking and was told to bleed the master clynder.
May 6, 2010 at 8:04 AM
SWILLIAMS
✓Experienced Mechanic
Bleeding the MC likely won't make a difference. Usually a sticking caliper is rust on the slider pins or a bad rubber line to the caliper, or rust and crud inside the caliper itself.
Mar 19, 2021 at 5:28 AM
