1998 Chevy Blazer losing water / running hot
RUSHJOHNSON
  • 1998 CHEVROLET BLAZER
  • 6 CYL
  • 185,000 MILES
My car is losing water and running hot. Usually takes about 15 miles to start running hot. I can't find a leak. I have replaced the thermostat, water pump, and flushed the radiator. Any suggestions, also there is no water in the oil.
Friday, July 23rd, 2010 AT 7:22 PM
KHLOW2008
  • 41,814 POSTS
Hi rushjohnson,
If coolant is depleting, there definitely must be some place it is getting to.
Get a presssure test done to check for the leaks.
Check if the cabin carpets are wet, that would indocate a leak at the heater core.
Saturday, July 24th, 2010 AT 8:52 AM
