1998 Chevy Blazer knocking
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
BLKBLZ1
I have a98 s-10 blazer 4.3L V6 262 cid&just put a new cam&lifters while a friend installed the cam bearings.The problem lies within timeing&misfiring&it knocks under 2500 rpm.I put new wires,plugs,cap,rotor,cmp&crk,sensors ,timeing chain&youname it,&Istill cant figure it out.Think it may be something with cam? Ran clearance check& seemed to loose. WHat do you think?
Nov 25, 2008 at 10:46 AM
SWILLIAMS
  • 597 POSTS
It sounds like the cam is timed wrong or there is a problem with the way you installed the distributor.
What does a scanner show for the timing and any codes it may have? What did the bottom end look like? I would recheck the cam and the timing.
Nov 25, 2008 at 2:40 PM
