1998 Chevy Blazer Ignition switch will not turn with key in
MEDICMUD
1998 Chevy Blazer 6 cyl Four Wheel Drive Automatic
My ignition switch will not turn when key is fully inserted. The door chim comes on but unable to turn key. Have tried moving gear shift and turning steering wheel to no avail. Can I remove switch and get the Blazer back home from grocery store?
Aug 15, 2009 at 5:27 AM
  • 110,248 POSTS
It isn't that easy. Either you have a bad tumbler or the actual switch has gone bad. To replace the tumbler, the steering wheel will need removed and part of the steering column. Because of the air bag, I recommend having it done by someone with experience. It can be deployed by accident.
Sep 2, 2009 at 1:10 AM
