1998 Chevy Blazer IDLE
13,900 MILES • 6 CYL • 4WD • AUTOMATIC
CHEVY2008
I HAVE A 1998 BLLAZER 4X4 IT HAS ABOUT 40,000 ON A NEW MOTOR WITH NEW WATER PUMP HOSES RADIATOR ETC U NAME IT ITS BEEN REPLACED OIL COOLING LINES REPLACED TWICE. ALL OF A SUDDEN WHEN I SIT STILL IT IDLES FIEN BUT ALL OF A SUDDEN THE GAUGES SLIGHTYL GO DOWN AND IT ACTS LIKE IT WANT TO ALMOST CUT OFF. THIS HAPPENS FOR ABOUT 2 SECS THEN IT IDLES AGAIN FINE .IT ONLY HAPPENS WHEN STOPPED AT STOP LIGHTS OR SITTING STILL. IT MAY HAPPEN SEVERAL TIMES WHILE WAITING FOR A LIGHT TO TURN. OX SENSOR REPLACE . THERE ISNT MUCH I HAVENT REPLACES. ANY SUGGESTIONS ON WHERE TO START. I DID HAVE A OIL LEAK WITH THE COOLER LINES WEEKS AGO SINCE THEN THE BELT WAS SQUEELING. COULD THIS BE AN ISSUE ?? WITH THE IDLE ??
Apr 16, 2008 at 10:37 PM
BMRFIXIT
  • 19,053 POSTS
do you have a check engine light on
if so get the codes
check it for tune up check cap and wires
also check for vacuum leak and the EGR valve
Apr 16, 2008 at 11:17 PM
