1998 Chevy Blazer how to replace a starter
MARICA
Engine Mechanical problem
1998 Chevy Blazer 6 cyl Automatic
could you please give me some free info on how to replace a starter or how to remove from a 1998 blazer
Jun 9, 2009 at 2:12 PM
BILLYMAC
  • 2,204 POSTS
hi. first disconnect the batt.#2 remove wires from starter.#3 remove two 15 mm bolts going vertical ,be careful starter will fall after you remove these two bolts. before you can get tothe starter bolts remove cover around the bottom of trans.
you will have to turn starter until you get it in a position to slide between the frame and eng. it is very tight but will go. good luck billymac
Jun 10, 2009 at 12:51 PM
