1998 Chevy Blazer high oil pressure
86,000 MILES • 6 CYL • 4WD • AUTOMATIC
KYLEMCNEEL
  • 34 POSTS
i have a 98 blazer. when it idles the pressure runs @ 25psi as soon as you give it some gas it jumps up @ about 2000 rpms its @ 80. any high and the gauge is buried. now i haven't checked it with a mechanical gauge yet. and i didn't change the pressure switch. this problem seem to happen all of a sudden . what would make the pressure run so high. usually if the oil pump goes the pressure runs low. so i'm stumped. any input would help
Feb 9, 2009 at 2:21 AM
RHALL77
  • 3,361 POSTS
it could be just your sensor, but have a mechincal gauge installed on it to make sure the pressure is normal. let me know what you find and ill see what i can do to help
Feb 9, 2009 at 7:03 AM
KYLEMCNEEL
  • 34 POSTS
ok. would you have any idea where to hook up a gauge would it be where the pressure switch goes? and if so would you have a clue what the normal operating psi. on the 4.3 vortec. i was thinking 20-60 thanks a ton i'll get back as soon as i can.
Feb 9, 2009 at 3:15 PM
RHALL77
  • 3,361 POSTS
yes hook it up at the oil pressure sensor area. the psi you said should be close to where you want it
Feb 10, 2009 at 12:59 AM
