i have a 98 blazer. when it idles the pressure runs @ 25psi as soon as you give it some gas it jumps up @ about 2000 rpms its @ 80. any high and the gauge is buried. now i haven't checked it with a mechanical gauge yet. and i didn't change the pressure switch. this problem seem to happen all of a sudden . what would make the pressure run so high. usually if the oil pump goes the pressure runs low. so i'm stumped. any input would help
Feb 9, 2009 at 2:21 AM
