1998 Chevy Blazer fuel tank pressure sensor
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
MICHAELBENOIT
would a bad fuel tank pressure sensor cause the fuel pump to not get power its not the fuel pump itself its brand new
Feb 22, 2010 at 9:32 AM
BLUELIGHTNIN6
  • 16,542 POSTS
no it would not prevent pump from running. check fuse and fuel pump relay, if OK check wiring harness to the fuel pump .
Feb 23, 2010 at 3:30 PM
