1998 Chevy Blazer Fuel system
INSEPTER
  • 1998 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 160,000 MILES
My truck won't start. The fuel pump has been replaced twice before. I can hear the fuel pump when I put the truck in the run position. I also took the fuel line off the fuel filter to see if fuel was going through the filter and it is. I haven't ruled anything out but I don't think it's the filter or the pump. I put gas in the throttle body and it fires up untill that fuel runs out
Monday, December 7th, 2009 AT 9:46 AM
JDL
  • 16,098 POSTS
Welcome to the forum, I'd use a gage and check fuel pressure, 60-66 psi, key on engine off. The best cleaning procedure for the injectors and poppets is a shop procedure. If injectors and poppets are the problem?
Monday, December 7th, 2009 AT 10:23 AM
