i just bought a fuel pump pigtail ,the problem is i wired it up to the the harness the same way and pluged it in and the fuel pump wont go on,the wireing is almost the same the harness is purple,black,yellow,and black with white stripe,the pig taiil is purple,black,black with white stripe,and gray,and it does not work,the wireing on the harness,is thiner,on the pig tail is thicker,can you please help.
Feb 20, 2009 at 10:53 AM
