1998 Chevy Blazer fuel pump pigtail
176,000 MILES • 6 CYL • 4WD • AUTOMATIC
MAGNAVORE
i just bought a fuel pump pigtail ,the problem is i wired it up to the the harness the same way and pluged it in and the fuel pump wont go on,the wireing is almost the same the harness is purple,black,yellow,and black with white stripe,the pig taiil is purple,black,black with white stripe,and gray,and it does not work,the wireing on the harness,is thiner,on the pig tail is thicker,can you please help.
Feb 20, 2009 at 10:53 AM
BLACKOP555
  • 10,386 POSTS
you getting power before replacing pigtail?
as key in igniiton in on position turning this?
are you getting power after replacing pigtail?
Mar 1, 2009 at 1:26 PM
