1998 Chevy Blazer fuel pressure
RUSTYNAILS
Engine Mechanical problem
1998 Chevy Blazer 6 cyl Two Wheel Drive Automatic
ran low on oil engine cut off now no fuel pressure .
Feb 7, 2010 at 2:28 AM
JDL
  • 16,098 POSTS
Hi, check ecm B fuse, underhood electrical center. Use a testlite on the fuse, see if both legs are hot. Circuit should be hot all the time. Do you suspect internal engine damage, because of oil issue?
Feb 7, 2010 at 2:51 AM
