1998 Chevy Blazer front end problems
104,000 MILES • 6 CYL • 4WD • AUTOMATIC
JQUESTER
car shakes when decelerating at 32 mph and at 16 mph like you going over a steel grated bridge. It's a little noticeable while accelerating but very noticeable when decelerating all the way until stopped. It doesn't change when steering side to side or putting the car in neutral. Checked the sway bar...that's fine. Jacked up the front end and both tires have side to side play. No play at the tie rod ends. No Top to bottom play in the wheel. Any ideas?
Feb 14, 2009 at 5:11 AM
RACEFAN966
  • 5,029 POSTS
Have you check the drive line ujoints? Check the front shaft and the rear shaft. Let me know what you find.
Feb 14, 2009 at 5:16 AM
