1998 Chevy Blazer Float sticking in gas tank
MMET67
1998 Chevy Blazer 6 cyl Four Wheel Drive Automatic
Is there any easy way to stop a float from sticking in the gas tank? I will fill up my Blazer but it will still read "Empty". I just don't want to have to remove the gas tank if possible. Thanks
Jun 6, 2008 at 12:19 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:a260e78384="mmet67"]1998 Chevy Blazer 6 cyl Four Wheel Drive Automatic
Is there any easy way to stop a float from sticking in the gas tank? I will fill up my Blazer but it will still read "Empty". I just don't want to have to remove the gas tank if possible. Thanks[/quote:a260e78384]
Well, don't want to be barer of bad news, but, no...
In my experience it is usually the sending unit shorting out and not the float. It could also possibly be the Wiring Harness chevy has had problems with them and recommend replacing the harness when changing the pump assembly.
Jun 7, 2008 at 12:18 AM
