1998 Chevy Blazer caliper sticking
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
ROBERT930
I replaced the front caliper on the drivers side because it was sticking , after replacing it the very next day it was sticking again what should I be looking at now this is puzzling me
Apr 10, 2010 at 4:46 AM
MERLIN2021
  • 17,250 POSTS
Drive it till it starts to bind or you notice drag, jack that wheel up, chock the rear wheels, put it in neutral, does the wheel spin, if not or it's hard to turn, open the bleeder screw, does it spin freely now? if yes, replace the flex hose, I recommecnd doing the same work to BOTH front brakes, this will elimante any issues with pulling to one side! Also both fronts are the same age and condition, if you don't do both now, you will real soon!
Mar 19, 2021 at 4:43 AM
