1998 Chevy Blazer Brake Light
177,000 MILES • 6 CYL • 4WD • AUTOMATIC
KRESTINA856
I have a 1998 chevy blazer and my brake light won't work. I've checked the fuses and changed the bulb light and still nothing. When i tap the brake the only light that comes on is the right brake light. On the left side i don't have a brake lght or a reverse lght but my turn signal works. I need help...
Feb 5, 2009 at 9:45 AM
F4I_GUY
  • 3,302 POSTS
You will need to check for power and ground at the light socket(s). Get yourself a test light or a voltmeter to check this.
Feb 7, 2009 at 3:24 AM
