1998 Chevy Blazer bogging down when getting up to speed
GEODA5
  • 1998 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 140,000 MILES
Whe we take off from a stop it seems like it bogs down on acceleration
Friday, January 15th, 2010 AT 7:23 AM
Check and test the following below:
Oygen Sensor
Catalytic Converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Cap and Rotor
Note:If it doesn't apply, disregard.
Friday, January 15th, 2010 AT 9:04 AM
