1998 Chevy Blazer altanator plug
147,843 MILES • 6 CYL • 4WD • AUTOMATIC
TEAM_AUDIOWORKS
i am having a problem with my altnator not wanting to start charging on cold start up it will take 10min-30min to start charging the battery are new and the altnator also it does the samething i
the plug on the bank of the altnator is kinda like a wake up to tell the alt. to start charging right? the pluse wire should have 12v but mine only has 4.5v i was told the the wire was wired right in to the ign. but i trace the wire to the pcm so is something wrong with the pcm or somthing else
Sep 16, 2008 at 2:46 PM
  • 75,988 POSTS
Sounds like the field generation control of the powertrain control module
Sep 16, 2008 at 6:06 PM
