1998 Chevy Blazer
198,000 MILES • 6 CYL • 2WD • AUTOMATIC
TROLLERON
my 98 blazer has recently started turning over but it will not start the fuel pump seems to be working but it it will continue to do it till the battery runs down i jump it off and most of the time it will fire right up i was told i was using the wrong size battery could this be true
Jun 21, 2010 at 4:20 PM
INTERNETMECHANIC
  • 700 POSTS
With an extended crank sooner or later it will run the battery down. If the battery runs down take it off and get it charged up. You shouldn't use the alternator to charge a dead battery. Some of the national brand autostores will check the battery for you and charge it if needed?
How long since a tune-up? Use a gage and check fuel pressure. Some of the national brand auto stores used to loan out a fuel pressure gage, if you don't have one. Do you have the spider fuel system? Proper Fuel pressure can be critical.
Jun 22, 2010 at 7:02 AM
