Just so that we have some documentation to go with this in case others have this issue, here is a guide that will help with how to figure this out:
Also, below is the wiring diagram that you will need to find the specific circuits needed to determine if the switch is the issue. Basically you need to test voltage coming out of the switch at the fuses.
Please let us know if you have questions on this. Thanks
Images (Click to enlarge)
Jul 28, 2021 at 6:34 AM
