1998 Chevy Blazer
135,000 MILES • 6 CYL • 4WD • AUTOMATIC
FELIPE0303
I have 2 questions reguarding my chevy 98 blazer that I hope you can help me out with. First of all the RPM is very low. I have already performed all the rutine tune-up, but that didnt seem to help. And my second question is when i start the truck and i've waited for it to mark that the engine is at least 1/4 of the way hot enough, and i get it moving at first it will shake, wobble, and pull a little while i press the pedal.It will continue to do this untill i get to at least 45 MPH. It will stop doing it once i make a complete stop, but when it runs again it will start all over again. This will continue to go on untill the engine marks that its at the correct temperature 1/2 way down. Im hoping you could help me figure out what it could be, and if it could be more serious.
Feb 23, 2010 at 2:51 PM
  • 110,251 POSTS
It sounds like it could be a few things. Has the check engine light come on? Have you checked the catylatic converter to make sure it isn't partially plugged?
Let me know
Feb 24, 2010 at 12:02 AM
FELIPE0303
That was my initiall concern there was no check engine light on, but i went to get it checked anyway and they said that the check engine light had been erased. Now i have just bought it, and the guy that sold it to me said there was no problem it just needed a tune up. But now that I went to get it checked out they said it might be one of three; the spark plug cables, the spark plugs, or the injectors. Now as i said before i just did the tune up so i dont think spark plug is the problem, and the cables... I had a problem with these with my dodge truck a while ago but i really dont think its that. So im leaning more to it being the injectors. Would you say i have a good chance of it being the injectors or more to it being one of the others?
Feb 24, 2010 at 6:37 PM
