1998 Chevy Blazer
BREZE
Heater problem
1998 Chevy Blazer V8 Four Wheel Drive
where does the vacuum for the blend door begin?
Jan 12, 2010 at 4:47 AM
BREZE
[quote:9f903dab2a="breze"]Heater problem
where does the vacuum for the blend door begin?[/quote:9f903dab2a]i have looked to try to find a diagram of the vacuum system but have not found anything
Jan 12, 2010 at 4:49 AM
TOOOMANYTOYS
  • 513 POSTS
The vaccum starts at the intake manifold on the driver side of motor. It then t's off to the evap canister. You can see the hose go in the inside of vehicle at the firewall right behind the motor. These hoses have an issue with becoming brittle and cracking.
Jan 12, 2010 at 4:59 AM
