1998 Chevy Blazer
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
DRAGONFLY6
every time i have to spray starter fluid or gas in to the intake to start it it has slowly got worse since ive had it at first it was just in the mornings then every time i shut it off id only have to spray once but now i have to do it a couple of time if it dosent die trying
Dec 11, 2009 at 5:43 AM
JDL
  • 16,098 POSTS
welcome to the forum. The spider fuel system is known for problems, a shop cleaning procedure might fix it? If that is the problem? You can use a gage and check fuel pressure.
Dec 11, 2009 at 7:16 AM
