1998 Chevy Blazer
94,000 MILES • 6 CYL • 4WD • AUTOMATIC
RODGER1998
i saked you about my blazer and i cant get it i will ask again i put it on a code reader and it came up evaporative emission system pressure sensor/switch low input and it will not start
Jan 14, 2009 at 6:04 AM
JDL
  • 16,098 POSTS
Hi, somebody correct me if I'm wrong. I don't think that a problem on that system will keep the vehicle from starting?
If you have the spider fuel system, they are noted for problems. Have you done any basic tests?
Have a helper crank it, while you check for spark at the plugs. If you have plenty of spark everywhere, check the fuel system. You need a fuel pressure gage, to check pressure.
Jan 14, 2009 at 6:51 AM
