1998 Chevy Blazer
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
CALI925
My truck died in mid-drive and wouldnt start again. we tried jumping it, timing chain is fine, the fuel pump is ok, and so are the coils. Someone mentioned it could be the internal computer? it is the vortec engine feedback pleasE!
Dec 6, 2008 at 8:16 AM
  • 110,248 POSTS
Hi:
Are you sure that you are getting spark to the plugs and fuel?
Dec 6, 2008 at 4:34 PM
CALI925
Yes. My friend zapped himself checking that too. Sparks and wires are all good. The car died as though the timing belt/chain snapped, but it didn't.
Dec 6, 2008 at 10:52 PM
  • 110,248 POSTS
Hi:
If you're getting fuel and spark, the only thing left is timing. Is the car backfiring or doing anything? Have you checked to make sure the distributor is turning? (if it has one)
Dec 7, 2008 at 11:01 AM
CALI925
No backfiring. Has all electric too.
Dec 7, 2008 at 11:05 AM
  • 110,248 POSTS
Make sure the distributor is turning (have a helper crank the engine, remove the distributor cap, and see if the rotor spins when the engine cranks. If it is, the last things to check are timing and then compression.
Dec 7, 2008 at 11:18 AM
