1998 Chevy Blazer
12,000 MILES • 6 CYL • 2WD • AUTOMATIC
TERRYARGUELLES
emergency brake stopped working, will not set
Nov 23, 2008 at 7:47 AM
SWILLIAMS
  • 597 POSTS
What does the pedal do when you step on it?
You could have a broken spring or cable end right at the pedal assembly. Or the front or rear actuator cables could be broken. If this is on a 4 wheel disc brake vehicle it could also be that the rear shoes for the parking brake have failed or rusted apart.
Nov 25, 2008 at 3:45 PM
