1997 Chevy Blazer Wipers
MARIAD2619
  • 1997 CHEVROLET BLAZER
Electrical problem
1997 Chevy Blazer 6 cyl Four Wheel Drive Automatic 185.00 miles
Why wont the rear window wiper work?
Thursday, March 5th, 2009 AT 8:46 AM
JDL
  • 16,098 POSTS
Hello, did you check the fuses? Park/lamps fuse 20 amp, hot all the time. Radio fuse 20 amp, goes hot when you turn on the key. My info shows those fuse circuits supply feed to the rear wiper. Check the fuses and that the fuse circuits are hot, when they should be.
There is also a ground circuit and a cutout switch for that motor.
Thursday, March 5th, 2009 AT 9:19 AM
